查看: 7831|回复: 27
实战:TCL L43F3800A--MT07P机芯电视不开机
发表于: 2018-8-6 15:25:44
生意正忙,又来活了,一台TCL L43F3800A--MT07P机芯电视。
故障现象:指示灯亮,二次不开机,测量电源板电压输出正常,判断故障部位在主板。
这机芯刚开始时还不会修,但最近学习的多了,修的也多了,已是轻车熟路,开盖测主板各路DC供电和LDO供电均正常,此机存储器型号为东芝5D1K,坏EMMC已是通病,开始信心满满的干 EMMC,以前有备份,直接拿一片EMMC离线写入。
上机、试机,然后傻眼!上电指示灯常亮,无闪烁动作,说明板子工作不正常,难道芯片或焊接有问题?  再来一次,又拿一块芯片写入装机,故障不变,完犊子了,判断失误,看来不能凭经验维修了。
看下打印吧,本机的TX RX在USB接口那里,照片忘拍了,焊转接线,连到809F,(F看打印爽)
联机,打印:
2018-8-3, 15:12:23
COM9, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12, Printed byRT809F:
Boot-
DRAM Channel A Calibration.
1T = (79 - 17) = 62 delay cells
Clock frequency = 798 MHz, Clock period = 1253 ps, 1 delay cell =20 ps
Byte 0 : Gating(-31 ~ 32), Size=64 .
Byte 1 : Gating(-31 ~ 31), Size=63 .
Byte 2 : Gating(-31 ~ 32), Size=64 .
Byte 3 : Gating(-31 ~ 32), Size=64 .
error on bit 0 ,setup_time =hold_time =0!!
error on bit 1 ,setup_time=hold_time =0!!
error on bit 2 ,setup_time=hold_time =0!!
error on bit 3 ,setup_time=hold_time =0!!
error on bit 4 ,setup_time=hold_time =0!!
error on bit 5 ,setup_time=hold_time =0!!
error on bit 6 ,setup_time=hold_time =0!!
error on bit 7 ,setup_time =hold_time=0!!
error on bit 8 ,setup_time=hold_time =0!!
error on bit 9 ,setup_time=hold_time =0!!
error on bit 10 ,setup_time=hold_time =0!!
error on bit 11 ,setup_time=hold_time =0!!
error on bit 12 ,setup_time=hold_time =0!!
error on bit 13 ,setup_time=hold_time =0!!
error on bit 14 ,setup_time=hold_time =0!!
error on bit 15 ,setup_time=hold_time =0!!
error on bit 16 ,setup_time=hold_time =0!!
error on bit 17 ,setup_time=hold_time =0!!
error on bit 18 ,setup_time=hold_time =0!!
error on bit 19 ,setup_time=hold_time =0!!
error on bit 20 ,setup_time=hold_time =0!!
error on bit 21 ,setup_time=hold_time =0!!
error on bit 22 ,setup_time=hold_time =0!!
error on bit 23 ,setup_time=hold_time =0!!
error on bit 24 ,setup_time=hold_time =0!!
error on bit 25 ,setup_time=hold_time =0!!
error on bit 26 ,setup_time=hold_time =0!!
error on bit 27 ,setup_time=hold_time =0!!
error on bit 28 ,setup_time=hold_time =0!!
error on bit 29 ,setup_time=hold_time =0!!
error on bit 30 ,setup_time=hold_time =0!!
error on bit 31 ,setup_time=hold_time =0!!
HW Byte 0 : DQS(0 ~ 0), Size 0 ,Set 0.
HW Byte 1 : DQS(0 ~ 0), Size 0 , Set 0.
HW Byte 2 : DQS(0 ~ 0), Size 0 , Set 0.
HW Byte 3 : DQS(0 ~ 0), Size 0 , Set 0.
RX DQ/DQS calibration fail!
DATLAT calibration
no DATLAT taps pass
default tx dq PI delay value(16) is fail on bit 0!!
default tx dq PI delay value(16) is fail on bit 1!!
default tx dq PI delay value(16) is fail on bit 2!!
default tx dq PI delay value(16) is fail on bit 3!!
default tx dq PI delay value(16) is fail on bit 4!!
default tx dq PI delay value(16) is fail on bit 5!!
default tx dq PI delay value(16) is fail on bit 6!!
default tx dq PI delay value(16) is fail on bit 7!!
default tx dq PI delay value(16) is fail on bit 8!!
default tx dq PI delay value(16) is fail on bit 9!!
default tx dq PI delay value(16) is fail on bit 10!!
default tx dq PI delay value(16) is fail on bit 11!!
default tx dq PI delay value(16) is fail on bit 12!!
default tx dq PI delay value(16) is fail on bit 13!!
default tx dq PI delay value(16) is fail on bit 14!!
default tx dq PI delay value(16) is fail on bit 15!!
default tx dq PI delay value(16) is fail on bit 16!!
default tx dq PI delay value(16) is fail on bit 17!!
default tx dq PI delay value(16) is fail on bit 18!!
default tx dq PI delay value(16) is fail on bit 19!!
default tx dq PI delay value(16) is fail on bit 20!!
default tx dq PI delay value(16) is fail on bit 21!!
default tx dq PI delay value(16) is fail on bit 22!!
default tx dq PI delay value(16) is fail on bit 23!!
default tx dq PI delay value(16) is fail on bit 24!!
default tx dq PI delay value(16) is fail on bit 25!!
default tx dq PI delay value(16) is fail on bit 26!!
default tx dq PI delay value(16) is fail on bit 27!!
default tx dq PI delay value(16) is fail on bit 28!!
default tx dq PI delay value(16) is fail on bit 29!!
default tx dq PI delay value(16) is fail on bit 30!!
default tx dq PI delay value(16) is fail on bit 31!!
error: cannot find right boundary of DQM
error: cannot find left boundary of DQM
TX HW Byte 0 : DQS(-16 ~ -16), Size 1, Set 48.
TX HW Byte 1 : DQS(-16 ~ -16), Size 1, Set 48.
TX HW Byte 2 : DQS(-16 ~ -16), Size 1, Set 48.
TX HW Byte 3 : DQS(-16 ~ -16), Size 1, Set 48.
TX DQ/DQS calibration fail!
这么多的英文,我是肯定看不懂滴,找个翻译软件翻译一下。
2018-8-3,15:12:23
COM9,BaudRate:115200 bps,RXD:VGA-> 15,TXD:VGA-> 12,由RT809F打印:
Boot-
DRAM通道A校准。
1T =(79-17)= 62个延迟单元
时钟频率= 798 MHz,时钟周期= 1253 ps,1个延迟单元= 20 ps
字节0:门控(-31~32),大小= 64。
字节1:门控(-31~31),大小= 63。
字节2:门控(-31~32),大小= 64。
字节3:门控(-31~32),大小= 64。
位0错误,setup_time =hold_time = 0 !!
第1位错误,setup_time =hold_time = 0 !!
第2位错误,setup_time =hold_time = 0 !!
第3位错误,setup_time =hold_time = 0 !!
.........中间太长省略.........
第31位错误,setup_time =hold_time = 0 !!
HW字节0:DQS(0~0),大小0,设置0。
HW字节1:DQS(0~0),大小0,设置0。
HW字节2:DQS(0~0),大小0,设置0。
HW字节3:DQS(0~0),大小0,设置0。
RX DQ / DQS校准失败!
DATLAT校准
没有DATLAT点击通过
默认tx dq PI延迟值(16)在位0上失败!!
默认tx dq PI延迟值(16)在位1失败!!
默认tx dq第31位PI延迟值(16)失败!!
错误:无法找到DQM的右边界
错误:找不到DQM的左边界
TX HW字节0:DQS(-16~-16),大小1,设置48。
TX HW字节1:DQS(-16~-16),大小1,设置48。
TX HW字节2:DQS(-16~-16),大小1,设置48。
TX HW字节3:DQS(-16~-16),大小1,设置48。
TX DQ / DQS校准失败!
难道是主控问题?这打印和以前别的机芯好像不太一样,还是不太懂,那就再来一板斧,直接把主控干了,不行再说。
结果是必然的,还是不行,这么简单也用不着发贴了!
看来是该使出终极大招的时候了。。。
这就是我的大招,嘿嘿!
罗师傅明确指出DDR通讯故障,那还等啥,测,测,测,几个排阻测对地阻值......突然发现一组不正常,心中窃喜,有戏,每个排阻对地都是380,只有一个是670(二极管档,数字万用表)。
断开排阻,找出不正常的一端,风枪拆排阻后发现异常排阻脚阻值变为410,已接近正常,说明过孔故障可能性非常大,测过孔正面到反面有明显阻值,看来问题已找到,用0.25MM钻头,把过孔打了一个透,钻头也成功的留在过孔里。
拔出牺牲的钻头,找个细铜丝穿过焊好。
试机,指示灯亮下变暗,遥控可二次开机,打印明显变的有点正常的感觉!(因为英文只认识几个单词)。
正常打印:
2018-8-3, 15:57:34
COM9, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12, Printed by RT809F:
Boot-
1T = (81 - 17) = 64 delay cells
Clock frequency = 798 MHz, Clock period = 1253 ps, 1 delay cell =19 ps
Byte 0 : Gating(-32 ~ 33), Size=66 .
Byte 1 : Gating(-32 ~ 32), Size=65 .
Byte 2 : Gating(-32 ~ 33), Size=66 .
Byte 3 : Gating(-32 ~ 33), Size=66 .
HW Byte 0 : DQS(-11 ~ 13), Size 25 , Set 1.
HW Byte 1 : DQS(-13 ~ 12), Size 26 , Set 0.
HW Byte 2 : DQS(-9 ~ 14), Size 24 , Set 3.
HW Byte 3 : DQS(-11 ~ 14), Size 26 , Set 2.
DATLAT calibration
first_step= 11 total pass= 5 best_step=12 .
TX HW Byte 0 : DQS(3 ~ 26), Size 24, Set 14.
TX HW Byte 1 : DQS(3 ~ 27), Size 25, Set 15.
TX HW Byte 2 : DQS(2 ~ 24), Size 23, Set 13.
TX HW Byte 3 : DQS(1 ~ 26), Size 26, Set 13.
DRAM A Size = 768 Mbytes.
Boot
Start Pmain
0x0000a000
EMMC boot
CID:0xc6cd5287
:0x30006a8d
:0x30344745
:0x11010030
LZHS addr:0x00100040
LZHS size:0x0015e408
LZHS checksum:0x000000e7
store RSA & AES keys in DMX SRAM
LZHS begin
Boot
Start Lmain
MT5882 Boot Loader v0.9
后面太长就省略了。。。
装机,图像完美出现,联网升级,装机OK!
芯片换了一大堆,结果是过孔坏了,晕菜!
总结:弯路走多了,近路就会越来越多!
此文由郭俊举师傅(举G)提供,感谢他的付出!
学习课程已更新,欢迎大家进入学习。
入口:公众号首页-精选-案例直播。
发表于: 2018-8-10 09:33:11
版主有这个的数据吗?正好修这个
发表于: 2018-8-11 13:37:44
谢谢楼主图文并茂的维修经验分享
发表于: 2018-8-12 09:31:35
谢谢楼主分享维修过程
发表于: 2018-8-12 15:16:43
谢谢楼主图文并茂的维修经验分享
jing9981 该用户已被删除
发表于: 2018-8-14 18:24:13
提示: 作者被禁止或删除 内容自动屏蔽
发表于: 2018-8-16 17:51:36
过孔串线,是断开过孔一线安全,还是打孔安全呢----我怎么觉得引线安全.....
发表于: 2018-11-14 16:10:45
感谢超版分享维修过程啦,辛苦辛苦、、、
发表于: 2018-11-15 17:04:59
谢谢楼主分享维修过程
发表于: 2018-11-18 14:17:41
还是要仔细啊
GMT+8, 2024-4-27 03:16 , Processed in 0.078785 sec., 13 queries .
