查看: 1163|回复: 1
tp.ms3463s.pb801 please support loading vga data
发表于: 2018-5-24 17:44:09
> Memory write protection lifted fails, please follow these steps:
015:  -->1. Set the circuit board in standby mode, after that write again:
016:  -->2. Using MST official software, inside the "Setting" change "Serial Debugging Address" to 0xB2£¬
017:  --> Select the "Device" and then choose "ISP mode with pin WP is active high", after that writing it.
018:  --> 3. Use tweezers or a wire to shorted memory chip pin-3 & pin-8 0f 8 pin type 25xx, or pin-2 & pin-9 of 16 pins type 25xx, after that writing the chip. When the screen showed protection lifted successful, release the tweezers or the wire.
019:  --> 4.Removed memory from PCB board and offline erased it. After that solder back to PCB and start ISP.
020:  Write error, operation terminated.
tp.ms3463s.pb801
I am new member looking for advice
GMT+8, 2024-5-8 07:34 , Processed in 0.049044 sec., 10 queries .
