查看: 2785|回复: 5
求助TP.MS628M.PB818打印信息时什么故障
发表于: 2018-5-9 19:15:25
AutoDQS0-[56789ABCDEF][6789ABCDEF][56789ABCDE][456789ABCDE]-[0x99AA]
AutoDQS1-[56789ABCDEF][56789ABCDEF][456789ABCDEF][456789ABCDEF]-[0x99AA]
_U
Relocation Offset is: 00dda000
[AT][MB][start ub][315]
U-Boot 2011.06-00000-g25b7a0d-dirty (Sep 15 2015 - 15:33:44)
cvte_buildinfo: 25b7a0db_20150915_153329
[NOS] UtopiaInit
1st UTOPIARegisterToUtopia is done[MBoot] Driver Register to Utopia
uboot held at [2e1ddf60~2f500000],size=013220a0
CPU  : Madison
Board: BD_MST064B_10AVXM_14065_MADISON
DRAM:  245 MiB
Now running in RAM - U-Boot at: 2e600000
eMMC: DDR 48MHz
eMMC 3.68 GB [75FFF8h]
Get MAC from ethaddr env
MAC:  0x0: 0x25: 0x92: 0xb4:0x1b: 0xa1
msIR_Initialize
[AT][MBoot][Driver Init][593]
Changelist:        24543697
AC on
====cvte power on check usb and upgrade ====
<628> do_cvte_init_at_prama4env
Check USB port[0]:
Host type:2
scanning bus for devices...
[USB] interface[0] conf:1 value ff:
1 USB Device(s) found
       scanning bus for storage devices... 0 Storage Device(s) found
Check USB port[1]:
Host type:2
[USB] interface[0] conf:1 value 8:
       scanning bus for storage devices... bulk max packet size: ep 200 ep2 200
max lun:0
1 Storage Device(s) found
** Partition 0 not valid on device 0 **
** Unable to use usb 0:0 for fatload **
reading mk_bin.cfg
** Unable to read "mk_bin.cfg" from usb 0:1 **
** Partition 2 not valid on device 0 **
** Unable to use usb 0:2 for fatload **
** Partition 3 not valid on device 0 **
** Unable to use usb 0:3 for fatload **
** Partition 4 not valid on device 0 **
** Unable to use usb 0:4 for fatload **
** Invalid boot device **
reading /allupgrade_msd628_4G_512M_ref54.bin
** Unable to read "/allupgrade_msd628_4G_512M_ref54.bin" from usb 0:1 **
reading /allupgrade_msd628_4G_512M_sos.bin
** Unable to read "/allupgrade_msd628_4G_512M_sos.bin" from usb 0:1 **
warn!! no upgrade file in usb.
<628> custar = 0
<628> Upgrade File Not Find
<CVTE> do_is_need_burn_mac
<CVTE> do_cvte_get_mac_from_emmc
block_data[0]:00
block_data[1]:25
block_data[2]:92
block_data[3]:b4
block_data[4]:1b
block_data[5]:a1
<628> Read MAC Value-->00:25:92:b4:1b:a1
<628> EMMC MAC-->00:25:92:b4:1b:a1 , ENV MAC-->00:25:92:b4:1b:a1
<CVTE> do_is_need_burn_hdcpkey
CountcheckSum=0x5cb8, Filechecksum=0x5cb8
reading FAC_BOOT_MSD628.cvt
** Unable to read "FAC_BOOT_MSD628.cvt" from usb 0:1 **
block_data[0]:00
block_data[1]:25
block_data[2]:92
block_data[3]:b4
block_data[4]:1b
block_data[5]:a1
<2984> do_cvte_init_at_env_by_value AT_Read=0 OR AT_B=0 OR AT_T=0 AT_BOOTCH=0:
Same as console=ttyS0,115200 androidboot.console=ttyS0 root=/dev/ram rw rootwait init=/init LX_MEM=0xA800000 EMAC_MEM=0x40000 DRAM_LEN=0x40000000 LX_MEM2=0xA0000000,0xCF00000 cma_miu1=0xA0000000,0x4000000 KDebug=1 delaylogo=true BOOTLOGO_IN_MBOOT ENV_VAR_OFFSET=0x0 ENV_VAR_SIZE=0x10000 ENV=EMMC SECURITY=OFF
<628> AT Start UART Control-init_pram.AT_P=0
UART BUS OFF 1!!!
STR_DC_ON
_U
[AT][MB][start ub][279]
[NOS] UtopiaInit
CPU  : Madison
DRAM:  245 MiB
eMMC: DDR 48MHz
msIR_Initialize
[AT][MBoot][Driver Init][561]
DC XXon
block_data[0]:00
block_data[1]:25
block_data[2]:92
block_data[3]:b4
block_data[4]:1b
block_data[5]:a1
UART BUS OFF 1!!!
发表于: 2018-5-10 07:35:59
看信息应该是引导有问题吧
 楼主| 发表于: 2018-5-10 08:19:47
就是呆在开机画面
发表于: 2018-5-11 15:42:50
升级主程序,如果不行的话,就要换EMMC了!
发表于: 2018-5-24 21:28:18
UART BUS OFF 1!!!     中线关闭
发表于: 2018-11-26 12:09:36
这是我的正常打印信息,你对照吧
TP.MS628M.PB818.rar
1.39 KB, 下载次数: 48, 下载积分: 金钱 -10
GMT+8, 2024-5-6 22:53 , Processed in 0.060799 sec., 12 queries .
