查看: 2534|回复: 6
求助 这个打印信息提示是什么东西坏
发表于: 2018-1-24 20:23:17
Boot-
DRAM Channel A Calibration.
1T = (89 - 21) = 68 delay cells
Clock frequency = 750 MHz, Clock period = 1333 ps, 1 delay cell =19 ps
Byte 0 : Gating(-32 ~ 32), Size=65 .
Byte 1 : Gating(-33 ~ 34), Size=68 .
Byte 2 : Gating(-32 ~ 33), Size=66 .
Byte 3 : Gating(-31 ~ 31), Size=63 .
HW Byte 0 : DQS(-12 ~ 13), Size 26 , Set 1.
HW Byte 1 : DQS(-10 ~ 15), Size 26 , Set 3.
HW Byte 2 : DQS(-11 ~ 13), Size 25 , Set 1.
HW Byte 3 : DQS(-11 ~ 13), Size 25 , Set 1.
DATLAT calibration
first_step= 11 total pass= 5 best_step=12 .
TX HW Byte 0 : DQS(6 ~ 30), Size 25, Set 18.
TX HW Byte 1 : DQS(6 ~ 30), Size 25, Set 18.
TX HW Byte 2 : DQS(4 ~ 29), Size 26, Set 17.
TX HW Byte 3 : DQS(5 ~ 29), Size 25, Set 17.
DRAM A Size = 512 Mbytes.
Boot
Start Pmain
0x0000a000
EMMC boot
CID:0xa735b2d5
:0x3002dda5
:0x30344745
:0x11010030
LZHS addr:0x00100040
LZHS size:0x000d4bc0
LZHS checksum:0x00000048
store RSA & AES keys in DMX SRAM
LZHS begin
Boot
Start Lmain
MT5882 Boot Loader v0.9
Boot reason: A/C power on!!Load HDMI internal EDID.................
00 ff ff ff ff ff ff 00 41 0c 00 00 00 00 00 00
00 19 01 03 80 00 00 00 0a d7 a5 a2 59 4a 96 24
14 50 54 a3 08 00 81 c0 01 01 01 01 01 01 01 01
01 01 01 01 01 01 7f 21 56 aa 51 00 1e 30 46 8f
33 00 3f 43 21 00 00 1e a9 1a 00 a0 50 00 16 30
30 20 37 00 3f 43 21 00 00 1a 00 00 00 fd 00 32
4c 1e 50 10 00 0a 20 20 20 20 20 20 00 00 00 fc
00 33 32 50 48 46 35 30 31 31 0a 20 20 20 01 6c
02 03 24 74 50 90 05 04 03 07 02 06 01 1f 14 13
12 16 11 15 20 23 09 07 03 66 03 0c 00 20 00 00
83 01 00 00 01 1d 00 bc 52 d0 1e 20 b8 28 55 40
c4 8e 21 00 00 1e 01 1d 80 d0 72 1c 16 20 10 2c
25 80 c4 8e 21 00 00 9e 8c 0a d0 8a 20 e0 2d 10
10 3e 96 00 13 8e 21 00 00 18 8c 0a d0 90 20 40
31 20 0c 40 55 00 13 8e 21 00 00 18 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 f3
CEC Physical offset 9d
HDMI1 PA 0x20
HDMI1 checksum 0xf3
HDMI2 PA 0x30
HDMI2 checksum 0xe3
HDMI3 PA 0x10
HDMI3 checksum 0x3
HDMI4 PA 0x40
HDMI4 checksum 0xd3
SIF_Master0: V2 design
IR DATA register : 0x       0
Boot reason: A/C power on!!T8032 init A/C on case loader stage...
Load T8032 FW (addr: 0x  da6860, size: 21826)success!!
T8032 FW version: 1
T8032 change to loader stage...
LDR_FlashCopy 0xf010 0x59100 0x80
11010030:30344745:3002dda5:11010030
id1:00303034 id2:47453002
eMMC Name: UNKNOWN
1st MAC in EEP is valid (00:25:92:74:8a:09)
Boot reason: A/C power on!!<5507> getenv flag=0xa01, len=0x0b
clean_all_AT_ENV
<5507> getenv flag=0xa00, val=0xff
<5507> setenvbybuffer flag=0xa01, len=0x07
<5507> setenv flag=0xa0a, val=0xff
<5507> setenv flag=0xa0b, val=0xff
Do USB upgrade
u1USBBlock = 0x01505840
USB: Vbus turn up time = 376 ms, Max =1000 ms.
USB-2: insert.
USB-3: insert.
USB-2: ClassCode= 0x8, u4Diff=0 ms.
FIND_CLASS_MASS_STORAGE.
Wait USB medium to be mounted...
USB Medium on Device, Time = 408 ms.
USB block size = 512 bytes.
.<5507> clean_at_env for upgrade
<5507> setenv flag=0xa00, val=0xff
<5507> setenvbybuffer flag=0xa01, len=0x0b
.Upgrade File Name: allupgrade_5507_max30.pkg
Upgrade File Size: 0x000000001619fa0d Bytes
no such index 1
Msdc Erase Unit:0x100000
[LdrLedBlinkikng] upgrading! Start ot Init/Turn on timer!
Use internal integrity check API
open File = /mnt/usb_0/allupgrade_5507_max30.pkg
Encrypted header:
c8 3e 03 3c 7f e9 8a 26 8c c4 97 15 8b 48 47 d1    .>.<...&.....HG.
de 08 3a 80 40 de 46 4d eb 73 d7 95 16 d3 3c 23    ..:.@.FM.s....<#
09 ae 2a b1 6c 21 89 f7 36 84 8b 5f 80 fe 62 96    ..*.l!..6.._..b.
a5 e0 cf e0 b6 9a 44 bd 2f 89 dc 23 e7 a5 00 5d    ......D./..#...]
8f 31 29 f8 5f a1 5d 78 37 8c 4d a3 52 59 dd af    .1)._.]x7.M.RY..
89 ba dc 7c c1 db b8 1c 90 49 35 08 fb 53 5e 03    ...|.....I5..S^.
87 9a 1d fb ad 2b 6d af 9a 55 06 92 ef e8 7b 85    .....+m..U....{.
e6 9c 6c ee 53 56 92 0e
Header:
68 61 69 65 23 44 48 40 46 69 52 6d 49 44 54 56    haie#DH@FiRmIDTV
30 38 30 31 5f 30 30 32 32 38 38 5f 32 5f 30 30    0801_002288_2_00
31 5f 32 5f 30 30 32 5f 31 34 30 5f 30 30 31 5f    1_2_002_140_001_
34 39 5f 30 30 31 5f 32 38 5f 31 34 35 31 35 35    49_001_28_145155
36 33 32 39 00 00 00 00 00 00 00 00 00 00 00 00    6329............
25 79 09 31 00 00 00 00 6d 74 35 38 38 32 5f 63    %y.1....mt5882_c
6e 5f 61 6e 64 72 6f 69 64 00 00 00 00 00 00 00    n_android.......
Validate codefile HMAC
Encrypted digest:
9f 25 5a 09 f0 e5 b9 5e 7a f6 89 95 dc b0 44 f5    .%Z....^z.....D.
b6 e7 d8 41 41 ec 4b a5 fa 1e cd b4 65 29 28 76    ...AA.K.....e)(v
Download digest
90 86 e8 da bc 8a f8 91 b6 97 9a 13 65 3b 21 8b    ............e;!.
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
............................................................................................New HMAC
Signature matched
0x00000000 : 0x31, 0x34, 0x35, 0x31, 0x35, 0x35, 0x36, 0x33,
0x00000008 : 0x32, 0x39,
szCurVer=1451556329  CurVer =1451556329
################### szUpgVer=(1451556329)  szCurVer=(1451556329) result = 0
########## ->upgrade NOT ALLOW
no such index 3
USB upgrade stop
LDR_EEPUserDrvCheckMagic u4HeaderData=0x31180852, u4Magic=0x31180852
Boot reason: A/C power on!!<5507> getenv flag=0xa09, val=0x00
<5508> LDR_IsGoBootup prLdrData->u4WakeupReason:6
<5507> getenv flag=0xa08, val=0x00
<5507> getenv flag=0xf8d, val=0xff
<5507> getRecoveryStep step=255
<5507> setenv flag=0xb21, val=0xff
<5508> LDR_IsGoBootup AT_READ_FLAG=0, AT_B_FLAG=0
Boot reason: A/C power on!!PDWNC_Init
Boot reason: A/C power on!!LiGF: Set GPIO88 = 1.
Loader_ReadMsdc(14, 0, 0x0d000000, 2097152, 2097152)
Find panel index 6 from EEPROM
2 Find panel index 6(PANEL_CMO_37_H1) from EEPROM
PANEL_ReadSettingsFromEeprom u4ControlWord=0xffffffff, u1FacAtPanel=0xff, u1FacAtMap=0x0
before u4PanelControlWord = 0x00000021
LvdsDisplayBit = 0x00000020
IsLvdsOddSwOn = 0x00000000
IsLvdsMsbSwOn = 0x00000001
after u4PanelControlWord = 0x00000021
Curr panel controlword = 00000021
[SA7] vDDDSInit
[SA7] _fgVopllUseDDDS = True
[LVDS] VOPLL Initialize successful !
vDrvLVDSOn(),  FIFO skew = 0x506
jpeg_decode(0x0d000000, 2097152, 0x0f000000, 2097152, 0x11000000, 1366, 768)
Color:14 BmpAddr:0x11000000 Width:1366 Height:768
Panel_width=1366, panel_height =768
====u1FlipMirrorEnable 3
[OSD]DBG Timing is Front Scaler
[OSD]i4H=310 i4V=9
u4HaderAddr = 0x1989f000, u4DisAddr=0x198a0000
Panel 1366 x 768
*************u4BmpPitch=5472******************
u4SrcWidth=1366 u4Value=0
u4OutWidth=1366,u4OutHeight=768,u4OutX=0,u4OutY=0.
LDR_OsdDisplay(14, 0x11000000, 1366, 768) return 0
Flash load lzhs header from 0x80000 to dram(0x1bb87d0), size=2048
Decompression uboot to 0x01000000...
Flash load image from 0x80000 to dram(0x1bb87d0), size=0x3d098
Img Misc header is wrong
发表于: 2018-1-24 22:40:51
好像屏检测没过,还有就是乱码
发表于: 2018-1-25 18:22:46
貌似USB升级过程出错
发表于: 2018-1-25 21:52:07 来自手机
没升级成功吧,固件不对吧
 楼主| 发表于: 2018-1-26 16:17:22
langbenjimo 发表于 2018-1-25 21:52
没升级成功吧,固件不对吧
固件是原厂
发表于: 2018-1-30 14:39:07
加载开机LOGo失败吧   继续刷系统
GMT+8, 2024-4-25 06:36 , Processed in 0.054347 sec., 10 queries .
