查看: 2694|回复: 3
请大师们看看一台杂牌机主芯片是MSD6A628VX-003J的打印信息
发表于: 2017-12-18 08:21:04
   请大师们看看一台杂牌机主芯片是MSD6A628VX-003J的打印信息:
AutoDQS0-[456789ABCD][3456789ABCD][3456789ABCD][456789ABCDE]-[0x9888]
AutoDQS1-[3456789ABCDE][3456789ABCDE][3456789ABCD][3456789ABCDE]-[0x8888]
_U
Relocation Offset is: 03b00000
[AT][MB][start ub][295]
U-Boot 2011.06-00000-gc344e9f-dirty (Dec 11 2015 - 11:33:20)
cvte_buildinfo: c344e9f3_20151211_113307
[NOS] UtopiaInit
1st UTOPIARegisterToUtopia is done[MBoot] Driver Register to Utopia
uboot held at [3e0ddf60~3f400000],size=013220a0
CPU  : Madison
Board: BD_MST066B_10AVX_14091_MADISON
DRAM:  500 MiB
Now running in RAM - U-Boot at: 3e500000
eMMC: DDR 48MHz
eMMC 3.68 GB [75FFF8h]
Get MAC from ethaddr env
MAC:  0x0: 0x25: 0x92: 0xb9:0x5e: 0xdb
[CPU INFO] cpu opencreate instance at 3e1d77a8 with private size 44 bytes at 3e1d77f0
CPUIoctl - MDrv_CMD_CPU_QueryClock
[UTOPIA INFO] close moduleNames[38]: MODULE_CPU
msIR_Initialize
[AT][MBoot][Driver Init][588]
Changelist: 24543697
AC on
====cvte power on check usb and upgrade ====
<628> do_cvte_init_at_prama4env
Check USB port[0]:
Host type:2
scanning bus for devices...
[USB] interface[0] conf:1 value ff:
1 USB Device(s) found
       scanning bus for storage devices... 0 Storage Device(s) found
Check USB port[1]:
No USB is connecting
usb init failed
Error, couldn't init Lowlevel part
Check USB port[2]:
usb init failed
FAIL : can not init usb!!
<628> custar = -1
<628> USB Disk Not Found
<CVTE> do_cvte_get_mac_from_emmc
block_data[0]:00
block_data[1]:25
block_data[2]:92
block_data[3]:b9
block_data[4]:5e
block_data[5]:db
<628> Read MAC Value-->00:25:92:b9:5e:db
<628> EMMC MAC-->00:25:92:b9:5e:db , ENV MAC-->00:25:92:b9:5e:db
<2984> do_cvte_init_at_env_by_value AT_Read=0 OR AT_B=0 OR AT_T=0 AT_BOOTCH=0:
Same as console=ttyS0,115200 androidboot.console=ttyS0 root=/dev/ram rw rootwait init=/init LX_MEM=0x1A200000 EMAC_MEM=0x40000 DRAM_LEN=0x40000000 LX_MEM2=0xA0000000,0x1A800000 cma_miu1=0xA0000000,0x10000000 KDebug=1 delaylogo=true BOOTLOGO_IN_MBOOT ENV_VAR_OFFSET=0x0 ENV_VAR_SIZE=0x10000 ENV=EMMC SECURITY=OFF
<628> AT Start UART Control-init_pram.AT_P=0
UART BUS OFF 1!!!
  是EMMC问题还是其他问题?
发表于: 2017-12-18 09:26:57
串口没有打开
 楼主| 发表于: 2017-12-18 09:47:44
请问如何打开串口进后台升级,原机卡在开机画面,有数据吗大师?
发表于: 2017-12-18 21:10:37
用809H擦除EMMC.才能打开串口进后台升级
GMT+8, 2024-4-26 20:59 , Processed in 0.049880 sec., 9 queries .
