楼主: 深山秋韵
分享新科LEDTV-3201B打印信息
 楼主| 发表于: 2017-12-1 14:57:47
先锋LED-32B500打印信息
Xshell 5 (Build 1332)
Copyright (c) 2002-2017 NetSarang Computer, Inc. All rights reserved.
Type `help' to learn how to use Xshell prompt.
[d:\~]$
Connecting to COM1...
Connected.
  SPI BOOT
Console Initial OK
Maria10: BD_MST021B_10ALG_11313_64M
[MIU]: 64MB  - DDR2 800MHz
BIST_0 PASS.
77
  [23456789ABC][123456789ABC]
0076
MIU Initial OK
sar input test...
panel is********* 33MDrv_PNL_Init u32PnlRiuBaseAddr = A0200000
MDrv_PNL_Init u32PMRiuBaseAddr = A0000000
GE_SetOnePixelMode
First GOP driver instance, flush GWIN HW
set USB port auto switch to 0
Force to set USB port switch to 0
---927---------Data[0xFFFF][0]----bflag:0-------
_COPRO_Init: u32RiuBaseAdd = A0200000
R2 is HK!
#Jeffrey.duan power on panel 1
MApp_DMP_InitDMPStat
$$$$$DLC cap width=1366, height=768
@@@@DLC cap hhstart=91, hhEnd=1274
#####DLC cap vvstart=128, vvEnd=672
Disable Aeon
Disable Aeon Done
_u8CurrentProgramNumber= 90DSP code loaded successfully
ATVProInitialize
InputSourceType is 6
Set audio standard---fangfeng [boot step time]MApp_ATVProc_Initialize -----
*********msAPI_Music_StartInit1=0
>>>adjust MApp_Audio_AdjustMainVolume=20>>>
easpect is 0[effect OPEN]:0
 楼主| 发表于: 2017-12-1 15:19:31
新科LEDTV-3201B打印信息
[c:\~]$
Connected.
Macaw12: BD_MST031B_10AL0_11523
SPI BOOT (SPI引导)
Console Initial OK (初步确定控制台OK)
BIST_0 PASS.
76
  [23456789AB][123456789AB]
0066
MIU Initial OK
[XC,Version] 00589490
MApi_XC_Init, 558, pXC_InitData->stPanelInfo.eLPLL_Type=1
GE_SetOnePixelMode
[GOP_ALL][Driver Version]: 0087, BuildNum: 1887, ChangeList: 2147483647
[HAL_GOP_InitMux] ((gop4g<<2)|gop2g):1
[MST Macaw12 Utopia Version[12.1.57]
Force to set USB port switch to 1
switch potr 1
Error> Unknown USB port
g_u8DCOnOff = ON
POWERON_MODE_OFF >>
should go to standby!!!!!
Power down
MDrv_Power_ExecutePowerDown
=> StandBy
上面是待机,下面是开机打印信息
SPI BOOT
Console Initial OK
BIST_0 PASS.
76
0066
MIU Initial OK
GE_SetOnePixelMode
Auth OK
create Audio SHM data ...
Disable Aeon
Disable Aeon Done
DMP ColorCorrection ===== Check Audio Decoder Protection from hash-key IP =====
Hash-key Support DD.
Hash-key Support DD+.
Hash-key Support Dolby Pulse(MS10-DDT).
Hash-key Support DTS DMP.
Hash-key Support WMA.
Hash Key Check DRA Fail, no DRA license!!
===== Check Protection IP End                         =====
hdmi port1
hdmi ColorCorrection unsupport compress
MApi_XC_SetWindow failed because of InitData wrong, please update header file and compile again
========= CUS04_ATV_MM_M12 =========
DVB-T Software Version: 0.00
[Board]: BD_MST031B_10AL0_11523
[Panel]: M280DGJ_Q02_HD
[Tuner]: RDA5156
[DRAM TYPE]: DDR2_800
[MEMORY_MAP]: MMAP_64MB
[DRAM SIZE]: 64 MB
[FLASH SIZE]: 4 MB
[ATV]: PAL
[Mirror]: 0
[ENABLE_PWS]: 1
[ENABLE_POWER_SAVING_DPMS]: 1
[DEMO_FINE_TUNE]: DFT_LTM238HL01_C_HD
[ENABLE_DLC]
[DISPLAY_LOGO]
=> DC_BOOT (1)
PM Wakeup by SAR
BlueScreen Open when Source Change
发表于: 2017-12-6 10:47:15
好东西,值得收藏,太感谢了。
 楼主| 发表于: 2017-12-8 09:12:14
TCL LE39D39开机打印信息
Xshell 5 (Build 1335)
[d:\~]$
Connected.
  SPI BOOT
Console Initial OK
Maria10: BD_MST006B_10AVS_10315
MIU: DDR2_800MHz
BIST_0 PASS.
55
  [23456789ABC][23456789ABC]
0077
MIU Initial OK
-------gPanelTypeState = 1
E2PROM OK!
-------gMirrorPanelEN = 0
***stGenSetting.g_FactorySysSetting.u8PowerOnMode=2***
sar input test...
PJ_PanelID******** 6
g_PNL_TypeSel is 6
panel is********* 6MDrv_PNL_Init u32PnlRiuBaseAddr = A0200000
GE_SetOnePixelMode
-----reset ST_VIDEO.ePicture as NORMAL!-----
@@Enter MApp_InputSource_IHCSetting
Enter MApp_InputSource_IHCSettingDisable Aeon
Disable Aeon Done
***EN_POWER_AC_BOOT ***
ATVProInitializeDSP code loaded successfully
Set audio standard
>>>adjust volume>>>
>>>adjust volume>>>OffLineIntial:
i=0,i=1,i=2,i=3,i=4,i=5,i=6,i=7,i=8,i=9,i=10,i=11,i=12,i=13,i=14,i=15,
easpect is 0
easpect is 0***EN_POWER_AC_BOOT ***
panel is********* 6
=========dbgVersionMessage=========
[Board]: BD_MST6M182_TCL
[Tuner]: HTF2_8C_116CW
[DRAM SIZE]: 64 MB
[FLASH SIZE]: 4 MB
ENABLE_DEMO_FINE_TUNE-->: 1
[DEMO_FINE_TUNE]: DFT_STD_FULLHD_CMO216_H1L01
[ATV]: PAL
[ENABLE_PWS]: 0
[ENABLE_POWER_SAVING_DPMS]: 0
[ENABLE_DLC]
[MWE]
[DISPLAY_LOGO]
-------EEPROM ADDRESS DEBUG--------------
[BASEADDRESS_COMMON_DATA]=0xA10
[END_BASEADDRESS_COMMON_DATA]=OxA90
(sizeof(ATV_PROGRAM_DATA_STRUCTURE))=OxA44
[RM_MODE_SETTING_START_ADR]=Ox1694
[RM_SIZE_MODE_SETTING]=Ox834
[RM_ATV_LAST_START_ADR]=Ox1EC8
[RM_DTV_CHSET_START_ADDR]=0x1EC9
[RM_64K_USAGE]=0x17C0
[RM_GEN_USAGE]=0x710
[MS_GENSETTING-size =0x3A8]
[MS_GENSETTING_EXT-size =0x4F0]
-------END EEPROM ADDRESS DEBUG--------------
[gPanelTypeState=FHD(1)?HD(0)]: 1
[Panel]: CM2_4A_LCD39P
*******FHD****FHD******
[g_ProjectID]: 17
[PJ_PanelID]: 6
[PJ_GammaID]: 2
[PJ_PictureCurveID]: 12
[PJ_KeypadID]: 1
[PJ_KeypadCh]: 1
[PJ_IS_PANEL_MIRROR]: 0
[Region]******CN*****CN*****
[Code Version] = V8-0MS82CN-LF1V122
[Code Date]= Jul 14 2012
[Code Time]= 09:44:09
[effect OPEN]:0
current SOURCE_TYPE = 6
now process UI type: *YUV 1*
Map to InputSourceType: 16
*YUV 1*times:1,Signal:0
*YUV 1*times:2,Signal:0
*YUV 1*times:3,Signal:0
*YUV 1*times:4,Signal:0
*YUV 1*times:5,Signal:0
*YUV 1*times:6,Signal:0
AVG:0
bSrcCnt = 2,No:Signal:1,CHFlag:0
[Signal Plug Out]
-----------bHaveSignal:0
now process UI type: *RGB*
Map to InputSourceType: 0
*RGB*times:1,Signal:0
*RGB*times:2,Signal:0
*RGB*times:3,Signal:0
*RGB*times:4,Signal:0
*RGB*times:5,Signal:0
*RGB*times:6,Signal:0
AVG:0
bSrcCnt = 3,No:Signal:1,CHFlag:0
[Signal Plug Out]
now process UI type: *HDMI-1*
Map to InputSourceType: 23
*HDMI-1*times:1,Signal:0
*HDMI-1*times:2,Signal:0
*HDMI-1*times:3,Signal:0
*HDMI-1*times:4,Signal:0
*HDMI-1*times:5,Signal:0
*HDMI-1*times:6,Signal:0
AVG:0
bSrcCnt = 4,No:Signal:1,CHFlag:0
[Signal Plug Out]
now process UI type: *HDMI-2*
Map to InputSourceType: 24
*HDMI-2*times:1,Signal:0
*HDMI-2*times:2,Signal:0
*HDMI-2*times:3,Signal:0
*HDMI-2*times:4,Signal:0
*HDMI-2*times:5,Signal:0
*HDMI-2*times:6,Signal:0
AVG:0
bSrcCnt = 5,No:Signal:1,CHFlag:0
[Signal Plug Out]
now process UI type: *AV-2*
Map to InputSourceType: 3
*AV-2*times:1,Signal:0
*AV-2*times:2,Signal:0
*AV-2*times:3,Signal:0
*AV-2*times:4,Signal:0
*AV-2*times:5,Signal:0
*AV-2*times:6,Signal:0
AVG:0
bSrcCnt = 7,No:Signal:1,CHFlag:0
 楼主| 发表于: 2017-12-18 20:42:38
[0123456789A][0123456789A]-55
_nPD
U-Boot 1.1.6 (Aug 30 2010 - 11:56:13)
Board: MSTAR TITANIA (CPU Speed 504 MHz)
DRAM:  134217728
Skipping flash_init
Flash:  0 kB
NAND:  nand_bbt: searching bbt....Bad block table found at page 65472, version 0x01
nand_bbt: searching bbt.....Bad block table found at page 65408, version 0x01
128 MiB
MSVC00B000100100208811DA0000000
Set MIU0 group priority:c9.....
Set MIU1 group priority:c9.....
Change MIU0 select.....
Group0:d80   Group1:88    Group2:200   Group3:f1
Change MIU1 select.....
Group0:4200  Group1:e00   Group2:30    Group3:4000
EEPROM @0x0 read: addr 80200000  off 1ffa  count 1 ... cmd: md.b 0x80200000 0x1
80200000: ff    .
done
80200000: 5a5aa5ff    ..ZZ
data_1[1ffa]--->:ff
check_keypad is[0]--keypad_pressed is [0] ---check_version is[0]
0x00220000-0x07280000 : "mtd=3"
Volume KL found at volume id 0
read 4194304 bytes from volume 0 to 81000000(buf address)
## Booting image at 81000000 ...
   Image Name:   Linux-2.6.28.10-mstar
   Created:      2010-08-13   9:47:03 UTC
   Image Type:   MIPS Linux Kernel Image (lzo compressed)
   Data Size:    3331374 Bytes =  3.2 MB
   Load Address: 80400000
   Entry Point:  80404150
   Uncompressing Kernel Image ... OK
Starting kernel ...
Linux version 2.6.28.10 (root@localhost.localdomain) (gcc version 4.3.2 (Sourcery G++ Lite 4.3-51) ) #17 PREEMPT Fri Aug 13 17:46:48 CST 2010
LINUX started...
boot_command_line: console=ttyS0,115200 ubi.mtd=3,2048 root=ubi:RFS rootfstype=ubifs rw LX_MEM=0x2800000 EMAC_MEM=0x100000 DRAM_LEN=0x10000000 LX_MEM2=0x46104000,0x1E00000 MS_GOP0_MIU=0 mtdparts=edb64M-nand:128k(NPT),1m(BL0),1m(BL1),115072k(UBI),-(NA)
LX_MEM  = 0x400000, 0x2800000
LX_MEM2 = 0x46104000, 0x1E00000
CPHYSADDR(PFN_ALIGN(&_end))= 0x991000
EMAC_LEN= 0x100000
DRAM_LEN= 0x10000000
console [early0] enabled
CPU revision is: 00019554 (MIPS 34Kc)
Begin Titania3_setup
Determined physical RAM map:
memory: 02800000 @ 00400000 (usable)
memory: 01e00000 @ 46104000 (usable)
Wasting 32768 bytes for tracking 1024 unused pages
Initrd not found or empty - disabling initrd
Zone PFN ranges:
  DMA      0x00000400 -> 0x00008000
  Normal   0x00008000 -> 0x00020000
  HighMem  0x00020000 -> 0x00047f04
Movable zone start PFN for each node
early_node_map[2] active PFN ranges
    0: 0x00000400 -> 0x00002c00
    0: 0x00046104 -> 0x00047f04
  Normal zone: 768 pages exceeds realsize 0
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16393
No lease, forking to background
[upgrade_daemon.c] auto_net_detect_task Line:1469 Now start auto checking...
ping: bad address 'tvwg.dnethome.net'
[upgrade_daemon.c] net_isvalid Line:1311 check network state error!
发表于: 2018-2-24 20:59:22
送人玫瑰手有余香,谢谢楼主分享的资料...
发表于: 2019-3-6 20:17:23
thanks for sharing
发表于: 2019-3-11 14:34:58
thanks for your post
发表于: 2022-3-26 15:44:03
深山秋韵 2017-12-18 20:42
有这台机器的数据吗,我着急用——如有的话帮我发一个上来,万分感 谢
GMT+8, 2024-4-20 15:11 , Processed in 0.056154 sec., 10 queries .
