查看: 9335|回复: 19
分享新科LEDTV-3201B打印信息
发表于: 2017-11-25 07:49:11
Xshell 5 (Build 1332)
Copyright (c) 2002-2017 NetSarang Computer, Inc. All rights reserved.
Type `help' to learn how to use Xshell prompt.
[c:\~]$
Connecting to COM1...
Connected.
Macaw12: BD_MST031B_10AL0_11523
SPI BOOT
Console Initial OK
BIST_0 PASS.
76
  [23456789AB][123456789AB]
0066
MIU Initial OK
MDrv_PNL_Init u32PnlRiuBaseAddr = A0200000
MDrv_PNL_Init u32PMRiuBaseAddr = A0000000
[XC,Version] 00589490
MApi_XC_Init, 558, pXC_InitData->stPanelInfo.eLPLL_Type=1
GE_SetOnePixelMode
First GOP driver instance, flush GWIN HW
[GOP_ALL][Driver Version]: 0087, BuildNum: 1887, ChangeList: 2147483647
[HAL_GOP_InitMux] ((gop4g<<2)|gop2g):1
[MST Macaw12 Utopia Version[12.1.57]
set USB port auto switch to 0
Force to set USB port switch to 1
switch potr 1
Error> Unknown USB port
g_u8DCOnOff = ON
POWERON_MODE_OFF >>
should go to standby!!!!!
Power down
MDrv_Power_ExecutePowerDown
=> StandBy
上半部分是待机打印信息,下半部分是开机打印信息
SPI BOOT
Console Initial OK
BIST_0 PASS.
76
0066
MIU Initial OK
GE_SetOnePixelMode
Auth OK
create Audio SHM data ...
Disable Aeon
Disable Aeon Done
DMP ColorCorrection ===== Check Audio Decoder Protection from hash-key IP =====
Hash-key Support DD.
Hash-key Support DD+.
Hash-key Support Dolby Pulse(MS10-DDT).
Hash-key Support DTS DMP.
Hash-key Support WMA.
Hash Key Check DRA Fail, no DRA license!!
===== Check Protection IP End                         =====
hdmi port1
hdmi ColorCorrection unsupport compress
MApi_XC_SetWindow failed because of InitData wrong, please update header file and compile again
========= CUS04_ATV_MM_M12 =========
DVB-T Software Version: 0.00
[Board]: BD_MST031B_10AL0_11523
[Panel]: M280DGJ_Q02_HD
[Tuner]: RDA5156
[DRAM TYPE]: DDR2_800
[MEMORY_MAP]: MMAP_64MB
[DRAM SIZE]: 64 MB
[FLASH SIZE]: 4 MB
[ATV]: PAL
[Mirror]: 0
[ENABLE_PWS]: 1
[ENABLE_POWER_SAVING_DPMS]: 1
[DEMO_FINE_TUNE]: DFT_LTM238HL01_C_HD
[ENABLE_DLC]
[DISPLAY_LOGO]
=> DC_BOOT (1)
PM Wakeup by SAR
BlueScreen Open when Source Change
下面是主板
 楼主| 发表于: 2017-11-25 08:19:14
有线数字机顶盒打印信息Xshell 5 (Build 1335)
[d:\~]$
Connected.
BL(Boot Loader引导装载程序): Initialize...(初始化) Ver: bl-cl_20091117, bl_info-V0000Cfaf24918D0000171f/fc00001f/3fff0000
BL(Boot Loader引导装载程序): Jump to application...(跳转到应用)
Application Initialize...(应用程序初始化)
actual_nim_type_demo = 0x17,actual_nim_type_tuner = 0xe
Module_name:[TDM5510]
Module_edition:[1.0.0.0]
Module_build_time:[2007-07-30]
[Cas_conax_ui.c] conaxcas_ui_attach
[Cas_conax_ui.c] conaxcas_email_load_from_flash!
conax_mail_load_from_flash priv->mailinfor->conax_newCnt=0
conax_mail_load_from_flash priv->mailinfor->total_email=0
conax_mail_load_from_flash priv->mailinfor->all_num=0
0.conax_caslib_msg msgtype==0x1
load file failure!803aee5c, 8054fec8
jwt_pic_get_serviceid_buffer failing
mem_gif_init_module1
mem_gif_init_module2
mem_gif_init_module3
[Cas_conax_ui.c] conaxcas_popuposd
FREQ=395000,SYM=6875,MOD=7
FREQ=379000,SYM=6875,MOD=7
[Cas_conax_ui.c] conaxcas_refreshinterface
[Cas_conax_ui.c] conaxcas_getmailnotifystatus
[Cas_conax.c]  conaxcas_start test_cur_time=5290
[Cas_conax.c] conaxcas_start_ecm->service_id=6c,ecmpid[0]=15e8,ecmpid[1]=15e8,es_pid[0]=5d0,es_pid[1]=5d2
[Cas_conax.c] conaxcas_start_ecm des_link_ch ret=0,ecm_pid=0x15e8,desc_id=0x0,es_chid=0x0,es_pid=0x5d0,test_cur_time=16
[Cas_conax.c] conaxcas_start_ecm des_link_ch ret=0,ecm_pid=0x15e8,desc_id=0x1,es_chid=0x1,es_pid=0x5d2,test_cur_time=24
1.conax_caslib_msg msgtype==0x1
 楼主| 发表于: 2017-11-25 08:31:59
SPI BOOT
Console Initial OK
Maria10: BD_MST021B_10ALG_11313_64M
[MIU]: 64MB  - DDR2 800MHz
BIST_0 PASS.
77
  [123456789ABC][23456789ABC]
0067
MIU Initial OK
Init ITE 6633 OK
sar input test...
CHECK HDCP data:NG!
HDCP_INDEX = 198;
CHECK HDCP data:OK!GE_SetOnePixelMode
s8SN0(26) s8SN1(27)
g_u8DCOnOff = OFF
POWERON_MODE_OFF >>
Power down
=> DeepSleep (0xFF)
 楼主| 发表于: 2017-11-25 08:37:22
哪位朋友知道上面两项代表啥?
DRAM Channel A Calibration.
DRAM Input DQS Calibration fail !
DRAM Channel B Calibration.
发表于: 2017-11-25 08:51:21
中国就是落后,全是人家的文字,国人看起来费劲
发表于: 2017-11-25 10:05:34
Thank you for your experience sharing.
发表于: 2017-11-25 10:56:54
Thank you for your sharing
发表于: 2017-11-26 22:18:49
是用编程器·r809f打印得吗
 楼主| 发表于: 2017-12-1 11:04:20
daxuan 发表于 2017-11-26 22:18
是用编程器·r809f打印得吗
是CH341
 楼主| 发表于: 2017-12-1 11:07:01
新科ledtv-4006d打印信息
[d:\~]$
Connected.
Macaw12: BD_MST030B_10AL8_12052
SPI BOOT
Console Initial OK
BIST_0 PASS.
76
  [23456789AB][23456789AB]
0066
MIU Initial OK
MW_Usb_SetFacMode_Through_Usb_File: Begin
Error> MW_Usb_SetFacMode_Through_Usb_File: port 1 connection timeout
Start Version
[Board]: BD_CVMV59SH_APW
[DRAM SIZE]: 64 MB
[FLASH SIZE]: 4 MB
[Tuner]: R620D
[Panel]: LSC400HM11
[Rroduce_Time]: 20140717170802
Cultraview_Version: XINKE_W20140509_06_CN_V59SH_APW_LSC400HM11_B6253_110
End Version
上面是待机,下面是开机打印信息????
SPI BOOT
Console Initial OK
BIST_0 PASS.
76
0066
MIU Initial OK
GMT+8, 2024-3-19 15:09 , Processed in 0.060943 sec., 13 queries .
