查看: 5134|回复: 13
乐视s40airl开机有时会卡在广告后,马上转为待机状态
发表于: 2017-11-18 23:16:57
乐视s40airl开机有时会卡在广告后,马上转为待机状态,重开有时能进入节目,但放一会又待机,用U盘升级有时会卡住,即进度条不动,复位也不好用,有时复位都不能正常运行,因主板无打印口,用809H的杜邦线接口直联RX,TX通讯接口到主板上对应的TX。RX升能端口线上,开机能读出打印信息,请师傅帮忙看一下哪的故障
2017-11-18, 16:0:12
COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809H:
_U
Relocation Offset is: 1bf00000
[AT][MB][start ub][853]
U-Boot 2011.06-00000-g39fbebe-dirty (Jan 11 2017 - 21:14:43)
[NOS] UtopiaInit
1st UTOPIARegisterToUtopia is done[MBoot] Driver Register to UtopiaAC on
uboot held at [3c0ddf60~3e000000]
CPU  : Napoli
Board: BD_MST051D_20ANV_NAPOLI
DRAM:  480 MiB
Now running in RAM - U-Boot at: 3d100000
eMMC: HS200 200MHz
eMMC 7.28 GB [E8FFF8h]
original bootargs: console=ttyS0,115200 androidboot.console=ttyS0 root=/dev/ram rw rootwait init=/init LX_MEM=0x11900000 EMAC_MEM=0x100000 DRAM_LEN=0x40000000 LX_MEM2=0x3FF00000,0x20000000 LX_MEM3=0xB1400000,0x2EA00000 CORE_DUMP_PATH=/data/Logs/Log.0/core_dump.%%p.gz KDebug=1 delaylogo=true BOOTLOGO_IN_MBOOT ENV_VAR_OFFSET=0x0 ENV_VAR_SIZE=0x10000 ENV=EMMC SECURITY=ON IsUseFactorCmdbBin=0 pname=S240F 3d=2 Channel=LETV
getenv dtmb error
set default DTMB
getenv system_update error
no this env system_update
new bootargs: console=ttyS0,115200 androidboot.console=ttyS0 root=/dev/ram rw rootwait init=/init LX_MEM=0x11900000 EMAC_MEM=0x100000 DRAM_LEN=0x40000000 LX_MEM2=0x3FF00000,0x20000000 LX_MEM3=0xB1400000,0x2EA00000 CORE_DUMP_PATH=/data/Logs/Log.0/core_dump.%%p.gz KDebug=1 delaylogo=true BOOTLOGO_IN_MBOOT ENV_VAR_OFFSET=0x0 ENV_VAR_SIZE=0x10000 ENV=EMMC SECURITY=ON IsUseFactorCmdbBin=0 pname=S240F 3d=2 Channel=LETV
Get MAC from ethaddr env
MAC:  0xc8: 0xe: 0x77: 0xe6:0x16: 0xc0
msIR_Initialize
mmc change mount : factory1
Size of file "/device.ini" from mmc device 0 partition factory1: 88 bytes
Loading file "/device.ini" at offset 0x0 from mmc device 0 partition factory1
88 bytes read
mmc change mount : factory2
Size of file "/device.ini" from mmc device 0 partition factory2: 139 bytes
Loading file "/device.ini" at offset 0x0 from mmc device 0 partition factory2
139 bytes read
OnOffValue[0]: 0
InOutValue[0]: 1
OnOffValue[1]: 0
InOutValue[1]: 1
OnOffValue[2]: 0
InOutValue[2]: 1
read GPIO FLASH_WP reTryCnt : 0, reReadCnt : 0
audio effect chip is not exist!
Changelist:        00112233
Unknown command 'if_51OnRam_set' - try 'help'
setCtvFacTestMode==bootargs =console=ttyS0,115200 androidboot.console=ttyS0 root=/dev/ram rw rootwait init=/init LX_MEM=0x11900000 EMAC_MEM=0x100000 DRAM_LEN=0x40000000 LX_MEM2=0x3FF00000,0x20000000 LX_MEM3=0xB1400000,0x2EA00000 CORE_DUMP_PATH=/data/Logs/Log.0/core_dump.%%p.gz KDebug=1 delaylogo=true BOOTLOGO_IN_MBOOT ENV_VAR_OFFSET=0x0 ENV_VAR_SIZE=0x10000 ENV=EMMC SECURITY=ON IsUseFactorCmdbBin=0 pname=S240F 3d=2 Channel=LETV
AC on
Check USB port[0]:
No USB is connecting
usb init failed
Error, couldn't init Lowlevel part
Check USB port[1]:
usb init failed
Check USB port[2]:
Host type:2
scanning bus for devices...
[USB] interface[0] conf:1 value 9:
Wait for hub reset....
checking hub ports...
qHD Status => Halted (Stall/Babble/Error Counter=0)...0x48
flib_Host20_Send_qTD3 fail !
2 USB Device(s) found
       scanning bus for storage devices... 0 Storage Device(s) found
[ERROR] Factory_Check_Usb_Files:562: FAIL : can not init usb!!
Writing to MMC(0)... done
MPOOL size : 0x200000
AC on
mmc change mount : tvconfig
Loading file "/config/PM.bin" at offset 0x0 from mmc device 0 partition tvconfig
24575 bytes read
Wait for PM51 stand?ower Down
U
[AT][MB][start ub][850]
[NOS] UtopiaInit
1st UTOPIARegisterToUtopia is done[MBoot] Driver Register to UtopiaDC on
CPU  : Napoli
DRAM:  480 MiB
eMMC: HS200 200MHz
getenv dtmb error
set default DTMB
msIR_Initialize
88 bytes read
139 bytes read
OnOffValue[0]: 0
InOutValue[0]: 1
OnOffValue[1]: 0
InOutValue[1]: 1
OnOffValue[2]: 0
InOutValue[2]: 1
DC on
DC on
Wait for PM51 standby DRAM ...........PM51 run ok...........create instance at 3c1d7af0 with private size 184 bytes at 3c1d7b38
[ERROR] get_project_id:499: [york]get_project_id=0x0017  0x17
MDrv_PNL_Init u32PnlRiuBaseAddr = 1f200000
MDrv_PNL_Init u32PMRiuBaseAddr = 1f000000
[_MDrv_PNL_Init_LPLL][315]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_LPLL][317]u16HTotal=2200,u16VTotal=1130,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1130, u16DefaultVFreq=600
[_MDrv_PNL_Init_Output_Dclk][361]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_Output_Dclk][363]u16HTotal=2200,u16VTotal=1130,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1130, u16DefaultVFreq=600
[MApi_XC_MLG_GetStatus, 1555]No instance existed, please get an instance by calling MApi_XC_Init() first
Init PWM2[Utopia] T8 is not supportcreate instance at 3c1d7bf8 with private size 304 bytes at 3c1d7c40
[AutoTest][MBoot][JPD Decode]
[UTOPIA INFO] close moduleNames[35]: MODULE_NJPEG_EX
Size of file "/config/mmap.ini" from mmc device 0 partition tvconfig: 52947 bytes
Loading file "/config/mmap.ini" at offset 0x0 from mmc device 0 partition tvconfig
52947 bytes read
create instance at 3c1e4ad0 with private size 16 bytes at 3c1e4b18
[GOP INFO] gop opencreate instance at 3c1e4b30 with private size 108 bytes at 3c1e4b78
[IZZY] (_GOP_RegisterAllCBFunc)
[AutoTest][MBoot][Show Logo][2152]
Loading file "/config/tee.aes" at offset 0x0 from mmc device 0 partition tvconfig
128 bytes read
4886192 bytes read
[ERROR] GetImageSize:1964: wrong image size
[ERROR] _RawData_Authentication:1470: get tee image size fail
发表于: 2017-11-19 08:29:56
不懂不掺和
发表于: 2017-11-19 08:50:35
这个反应的正常开机信息,无法判断故障部位。这种故障应该检查主板各电压和虚焊。
发表于: 2017-11-19 09:07:46
我维修过一台,用809H擦除EMMC芯片在用U盘升级,使用不到一个月有 坏了,我发的芯片明天到货,换一片试一下。
发表于: 2017-11-19 11:15:54
这个真不懂,英文好麻烦啊。
 楼主| 发表于: 2017-11-25 20:16:36
我现在在线清空了EMMC后,重写了一个数据包,上电没反应了,电源灯都点不亮了,但提示刷写成功了,不知啥原因,求解!
发表于: 2017-11-27 19:29:15
不是同一个版本。
 楼主| 发表于: 2017-11-27 20:36:35
2017-11-26, 11:54:26
_U
[AT][MB][start ub][862]
U-Boot 2011.06-00000-g39fbebe-dirty (Oct 15 2016 - 17:25:18)
[NOS] UtopiaInit
CPU  : Napoli
DRAM:  480 MiB
eMMC: HS200 200MHz
UART BUS OFF!!
上电打印信息变这样了,串口总线咋关了呢,引导也没有运行]
GMT+8, 2024-4-16 17:39 , Processed in 0.054904 sec., 10 queries .
