查看: 6176|回复: 2
求帮忙 主板TP.R69 PD64组装机红灯亮不开机 附打印信息
发表于: 2017-7-5 16:46:45
按开关键或任何键无反应,打印信息如何 大师看一下是哪里问题
2017-7-5, 16:34:57
COM4, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12, Printed by RT809F:
J
Hello world!{m3a} svn-r(Mar 16 2015 15:57:38)
init_hwsetting_c
pre_hwsetting_c
post_hwsetting_c
parse hw setting DONE!
internal rom
force emmc
Normal boot
check boot media...
mmc_init...
emmc:read sys info
mmc_read_sysinfo . read sys info@emmc OK
HW: 0x00000ba0
AC: 0x00003de0
UB: 0x0004f3e0
EXT : 0x00002100
 ext fw RSA signature verify OK!
emmc:read uboot
 bootcode RSA signature verify OK!
GO
U-Boot 2012.07-TCL_ODM_Rtd2969_20150706/trunk/Rtd2969_ALI_QingJi/bootcode-svn1094 (Apr 09 2016 - 14:27:05)
RTC: Init...Running
SCPU: BISR testing ....
SCPU: Finish BISR testing (OK)
CPU  : Cortex-A17
[krsv] use default uboot memory:
bank[0] Start = 0x0, Size = 0x20000000
DRAM:  512 MiB
Watchdog: Enabled
IO Config 2= PIN_WIFI_CTR@0000000100014603
IO Config 2= PIN_BL_ON_OFF@0000000001010804
IO Config 2= PIN_BL_ADJ@00ffff9600800108
IO Config 2= PIN_LVDS_ON_OFF@0000000000010004
IO Config 2= PIN_KEYPAD_MENU@0000000a00000601
IO Config 2= PIN_KEYPAD_SOURCE@0000000a5c000601
IO Config 2= PIN_KEYPAD_RIGHT@0000000a1e000701
IO Config 2= PIN_KEYPAD_LEFT@0000000a3f000701
IO Config 2= PIN_KEYPAD_UP@0000000a3f000601
IO Config 2= PIN_KEYPAD_DOWN@0000000a1e000601
IO Config 2= PIN_KEYPAD_PWR@0000000a00000701
IO Config 2= PIN_HDMI1_HOTPLUG@0000000001010404
IO Config 2= PIN_HDMI2_HOTPLUG@0000000001010504
IO Config 2= PIN_HDMI3_HOTPLUG@0000000000000000
IO Config 2= PIN_FLASH_WP@0000000000014703
IO Config 2= PIN_HDMI_MHL_SELECT@0000000100012804
IO Config 2= PIN_MHL_CABLE_DETECT@0000000000000904
IO Config 2= PIN_HP_OUT_JD@0000000000004b03
IO Config 2= PIN_AMP_MUTE@0000000100010c04
IO Config 2= PIN_POWER_DETECT@0000000000002504
IO Config 2= PIN_POWER_EN@0000000100010b04
IO Config 2= PIN_LED_G@0000000100010604
IO Config 2= PIN_LED_R@0000000101010704
IO Config 2= PIN_LVDS_SEL@0000000000014303
IO Config 2= PIN_HDMI1_DETECT@0000000000004503
IO Config 2= PIN_HDMI2_DETECT@0000000000004403
Board: TCL tv030 Board
POWER ON: AC
Cache: Enabled
Non-Cache Region: 1 MB@0x0b300000
To setup mmu...
MMC:   MMC: NOT allocate buffer from non-cache area
emmc:mmc_initial(1) Apr  9 2016 14:27:19
Release SPI Pad !!!
HW Reset eMMC
reset finish...
RTD294x eMMC: 0
Release SPI Pad !!!
RCA= 0x0
mmc:mmccr_set_bits_width(324) bus width switch to 8bits
emmc: clk change to 50MHz
mmccr_set_clk: 0x18000204=0x08601001
RCA= 0x0
Device: RTD294x eMMC
Manufacturer ID: 11
OEM: 100
Tran Speed: 52000000
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 3.7 GiB
Bus Width: 8-bit
Factory: MMC
Factory: seq:0xee, blk:0xe000(pp:1), size:0x316400 (to 0xa900000)
get_bootparam:
------------tmp/factory/bin_panel/000BootParam.h found
BOOT_POWER_ON_MODE=0
BOOT_FAC_POWER_ON_MODE=0
BOOT_FAC_LVDA_MAP_MODE=0
BOOT_FAC_LVDS_PORT_MODE=0
BOOT_FAC_LVDS_BIT_MODE=1
BOOT_FAC_LVDS_MIRROR_MODE=1
BOOT_LOGO_ENABLE=1
CUSTOM_VIDEO1_LENG=0
CUSTOM_VIDEO2_LENG=0
BOOT_MUSIC_ENABLE=0
CUSTOM_AUDIO1_LENG=0
CUSTOM_AUDIO2_LENG=0
LOCAL_UPGRADE_EN=0
BOOT_TV_SYSTEM=1
IMGFILE_PATTERN not found
[bootparam.c 291]:can't IMGFILE_PATTERN
-------TALENT----->>>>>>boot_ac_on=1
-------TALENT----->>>>>>boot_fac_power_on_mode=0
boot_power_on_mode=0
get_layout:
------------tmp/factory/layout.txt found
BOOTPART=0
TAG=21
Factory_RO: MMC
[FAC_RO] No factory_ro data in eMMC
[ENV] read_env from factory failed
[ENV] Using default environment variables
Panel: Use parameters in tmp/factory/bin_panel/panel.bin
Panel: P51_HV430FHB_N4A
panel_init_1st
CRT reg1=0,reg2=0
##### drvif_clock_set_dclk : 144000000 ###########
Panel: ulFreq:144000000, nDPLL:152999552, Mcode:34, Ncode:3, offset:788
dclk_sel = 1
=== Panel Type : 0 ===
liquan:panel.c,1318,panel_interface_common boot_fac_lvds_map_mode =0
0860:88000000, 0864:0, 0868:88000000, 086c:0
DISPI: BISR testing ....
DISPI: Finish BISR testing done
DISPD: BISR testing ....
DISPD: Finish BISR testing done
=== Panel Index : 0 ===
GDMA_ConfigVFlip, linecnt_start = 0x3f7
GDMA module_init finish
Net:   rtl8139: fuse ready = a0000011
rtl8139: link status = 0000ffff
rtl8139: REALTEK RTL8139 @0xb8016800
Hit Esc or Tab key to enter console mode or rescue linux:  0
------------can't find tmp/factory/recovery
name=PIN_KEYPAD_PWR ppcb_enum.Name=PIN_KEYPAD_PWR, ppcb_enum.info=a00000701
Start Boot Setup ...
         FW Table to 0x0a820000, size=0x00000200 (0x0a820200)
         FW Table fr 0x02000000, fw count: 4
Normal boot fw follow...
Linux Kernel:
         FW Image to 0x00108000, size=0x0100a0c8 (0x011120c8)
         FW Image fr 0x02008000 (non-lzma)
Audio FW:
         FW Image to 0x81700000, size=0x0027bb28 (0x8197bb28)
         FW Image fr 0x03012200 (non-lzma)
         Enter standby, skip this entry
Video FW 1:
         FW Image to 0x81a00000, size=0x002e9e90 (0x81ce9e90)
         FW Image fr 0x0328de00 (non-lzma)
Video[image] data 1:
         FW Image to 0x86700000, size=0x0000b891 (0x8670b891)
         FW Image fr 0x03577e00 (non-lzma)
(rtkpm_clr_share_mem)2013/04/23 14:55
(powerMgr_setup_keypad_multi)2012/05/09 15:55
keypad param0=0xa00000701
kptype=1
kpidx=7
PCB_PIN_TYPE_LSADC
KEYPAD_PARM0=0x  17000a
Valid keypad paramteter have 1 set.
pm_event_msg=0x1
name=PIN_POWER_EN ppcb_enum.Name=PIN_POWER_EN, ppcb_enum.info=100010b04
got POWER_EN pin
(powerMgr_setup_power_en)2012/05/09 15:55
Power enable line have 1 set.
en_power para0=0x100010b04
GET_PIN_TYPE:4
pm_event_msg=0x100001
(powerMgr_setup_irda)2012/05/09 15:55
IrDA Protocol is 1
IR_KEY1=0xe31cc738
IR_KEY2=0xff00bf00
IR_KEY3=0x53ac9b44
IR_KEY4=0xf50a3e01
IR_KEY5=0x28d77887
IR_KEY6=0xad52df20
IR_KEY7=0xef102207
IR_KEY8=0xf50a4040
IR_KEY9=0xfe019088
IR_KEY10=0xe31cffef
IR_KEY11=0xb54acb04
pm_event_msg=0x1b0001
Kernel command line: androidboot.console=ttyS0 console=ttyS0,115200 envp=64100 flashtype=emmc mmcparts=rtkemmc:3866624k,786432k(/system),1572864k(/data),524288k(/cache),16384k(/res) root=/dev/mmcblk0p1 rootfstype=ext4 ro rootwait earlyprintk ac_on POWERDOWN
Starting kernel ...
Reset ethernet/disable interrupt/flush cache...
bootargs=androidboot.console=ttyS0 console=ttyS0,115200 envp=64100 flashtype=emmc mmcparts=rtkemmc:3866624k,786432k(/system),1572864k(/data),524288k(/cache),16384k(/res) root=/dev/mmcblk0p1 rootfstype=ext4 ro rootwait earlyprintk ac_on POWERDOWN
boot_jump_linux 0x00108000(0x0,0x138b,0x60100)
bsp_serial_init
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 3.10.0+ (qiaolingyi@qiaolingyi) (gcc version 4.8.3 (Realtek ASDK-4.8.3p1 Build 2003) ) #312 PREEMPT Thu Jan 21 16:52:03 CST 2016
[    0.000000] bootconsole [earlycon0] enabled
[    0.000000] cma: CMA: reserved 352 MiB at 02000000
[    0.000000]  System CPU has 1 UART.
[    0.000000]  System CPU uses internal timer interrupt.
[    0.000000]  Ethernet Mac address: 00:10:20:30:40:50
[    0.000000]  Base year of RTC is 2013.
[    0.000000] #@# rtk_init_early(480) release SB2_HD_SEM_NEW_5_reg
[    0.000000] Kernel command line: androidboot.console=ttyS0 console=ttyS0,115200 envp=64100 flashtype=emmc mmcparts=rtkemmc:3866624k,786432k(/system),1572864k(/data),524288k(/cache),16384k(/res) root=/dev/mmcblk0p1 rootfstype=ext4 ro rootwait earlyprintk ac_on POWERDOWN
[    0.000000] #@# IR_Init(1616) release SB2_HD_SEM_NEW_5_reg
EMCU ver:000000
(build: May 29 2015 &13:24:32)
share_reg[0x0]:0x1b0001
share_reg[0x1]:0x17000a
share_reg[0x2]:0x0
share_reg[0x3]:0x0
share_reg[0x4]:0x0
share_reg[0x5]:0x0
share_reg[0x6]:0x0
share_reg[0x7]:0x0
share_reg[0x8]:0x0
share_reg[0x9]:0x0
share_reg[0xa]:0x0
share_reg[0xb]:0x0
share_reg[0xc]:0x0
share_reg[0xd]:0x1
share_reg[0xe]:0xe31cc738
share_reg[0xf]:0xff00bf00
share_reg[0x10]:0x53ac9b44
share_reg[0x11]:0xf50a3e01
share_reg[0x12]:0x28d77887
share_reg[0x13]:0xad52df20
share_reg[0x14]:0xef102207
share_reg[0x15]:0xf50a4040
share_reg[0x16]:0xfe019088
share_reg[0x17]:0xe31cffef
share_reg[0x18]:0xb54acb04
share_reg[0x19]:0x0
share_reg[0x1a]:0x0
share_reg[0x1b]:0x0
share_reg[0x1c]:0x0
share_reg[0x1d]:0xb00
share_reg[0x1e]:0x0
share_reg[0x1f]:0x0
Pow pin have 0x1 set 0x0 MIN
0xa , 0xa sec
0x14 , 0x14 sec
0x1e , 0x1e sec
0x28 , 0x28 sec
0x32 , 0x32 sec
0x1 MIN
发表于: 2017-11-29 11:38:52
请问楼主修好了没?我同样的问题。不知楼主是如何连接查看打印信息
发表于: 2018-4-12 10:19:20
拆掉EMMC用809重写软件
GMT+8, 2024-3-29 20:10 , Processed in 0.053800 sec., 9 queries .
