楼主: yogesh
NAND FLASH BOOT PROBLEM
发表于: 2016-7-28 08:40:54
请告诉我如何到 ISP 模式由 RT809F 阅读 NAND 闪存 (TC58NVG1S3HTA10)
发表于: 2016-7-28 08:44:41
861110859 回复是    Nand 闪存芯片是拆除打开来读和写,
RT809F 扩展板,需要购支持反弹座,可以读取和写入。
发表于: 2016-7-28 09:01:48
我们中国的现在用RT809H   Nand 闪存芯片是拆除打开来读和写
发表于: 2016-7-28 09:03:38
Our Chinese RT809H Nand Flash memory chips are removed now open to read and write     OK
 楼主| 发表于: 2016-9-24 13:41:14
please  send me supported device list   of RT809H  programmer
 楼主| 发表于: 2016-11-20 19:33:14
001:  Programmer is not connected.
002:  The currently selected:S29AL008D70TFI02@TSOP48, capacity: 8Mbits, 1Mbytes.
003:  Adapter model£oRT-TSOP48-1, 0.5, 12*18, Pin to Pin
004:  Serial number:20161007122248-045821  ,PCB V1.60,Boot V1.00
005:  Download device programming algorithm......
006:  Algo update OK
007:  >------------------------------------OK---------------------------------------<
008:  The pin detection value is 0xFFFFFFFFCDFF£&#172;Device library number is 0xFFFFFFFFCCFF&#161;£
009:  Chip pins contact is detected OK.
010:  Ignore the chip ID to continue.
011:  Start reading chip......
012:  Read successful£&#172;Elapsed time£o0.188 seconds&#161;£
013:  Auto verifying...
014:  Verification successful£&#172;Elapsed time£o0.189 seconds&#161;£
015:  Buffer data checksum: 16bits_0xFA16 £&#172;32bits_0x08CCFA16 :
016:  Elapsed time: 0.388 seconds£&#172;average speed of 5405030 bytes/sec.
017:  >------------------------------------OK---------------------------------------<
018:  The currently selected:S29AL008D70TFI01@TSOP48, capacity: 8Mbits, 1Mbytes.
019:  Adapter model£oRT-TSOP48-1, 0.5, 12*18, Pin to Pin
020:  Download device programming algorithm......
021:  Algo update OK
022:  >------------------------------------OK---------------------------------------<
023:  The pin detection value is 0xFFFFFFFFCDFF£&#172;Device library number is 0xFFFFFFFFCCFF&#161;£
024:  Chip pins contact is detected OK.
025:  Chip ID selected does not match the current ID, operation has been terminated.
026:  ID verification error.
027:  Point "read" will pop up "save" dialog box, "write" will pop up the "open" dialog box.
028:  The currently selected:NAND_AUTO
029:  Download device programming algorithm......
030:  Algo update OK
031:  >------------------------------------OK---------------------------------------<
032:  The pin detection value is 0xFFFFFFFFDDFF£&#172;Device library number is 0xF18F00799C0&#161;£
033:  Chip pins contact is detected OK.
034:  TotalPageNum: 0x100,PageNumInBlock: 64,PageSize: 2112
035:  NewMFR: 0x5A , ID: 0x5A5A5A5A5A5A5A5A, 3.3V, CE:1, 16bit, Col: 2, Row: 2, TLC.
036:  PageSize:4096B, OobSize:64B, BlockSize:128KB, ChipSize:0MB.
037:  Recognition of the NAND parameters is special
 楼主| 发表于: 2016-11-20 19:37:39
the chip number  is S29AL016D70TFI02  BUT   RT809H  programmer  is not reading  please  my problem solve
发表于: 2018-3-30 22:20:18
RT809F好像不能在线读nand吧
发表于: 2019-4-7 19:07:09
001:  Serial number:20181016110401-011135  ,PCB V1.80,Boot V1.00
002:  >------------------------------------OK---------------------------------------<
003:  Using Mode-A to scan VGA port...
004:  Mode-A cannot identified the circuit board, change line sequence to Mode-D and continue to identifying...
005:  Mode-D cannot identified the circuit board, change line sequence to Mode-B and continue to identifying...
006:  Mode-B cannot identified the circuit board, change line sequence to Mode-C and continue to identifying...
007:  ISP line sequence modes A-B-C-D also cannot identified the circuit board or chip, you can have a look at the chip and then manually select.
008:  Scan SPI extension interface...
009:  Boot error, please check whether the EC chip is supplied voltage and ISP cable is connected properly or not. The ISP cable should not exceed 10cm in length.
010:  Chip is not recognized, please check whether the circuit board is powered on and ISP cable is connected properly or not. If all ok, it maybe the chip is damage.
HELP ME.
GMT+8, 2024-4-20 04:24 , Processed in 0.047752 sec., 10 queries .
