楼主: admin
RT809F编程器—仁宝代工笔记本EC在线读写_KB9012_9010_9016_KB9022_联想_华硕_宏基_HP
发表于: 2018-1-12 14:29:27
lenovo g505 how to connect KB9012QF multocontroller, using rt809h?
sorry for the mistake
发表于: 2018-1-12 14:32:26
发表于: 2018-1-12 14:48:33
help with connecting with rt809h
发表于: 2018-1-21 16:20:55
Using Mode-A to scan VGA port...
084:  Mode-A cannot identified the circuit board, change line sequence to Mode-D and continue to identifying...
085:  Mode-D cannot identified the circuit board, change line sequence to Mode-B and continue to identifying...
086:  Mode-B cannot identified the circuit board, change line sequence to Mode-C and continue to identifying...
087:  Scan SPI extension interface...
088:  Boot error, please check whether the EC chip is supplied voltage and ISP cable is connected properly or not. The ISP cable should not exceed 10cm in length.
089:  Chip is not recognized, please check whether the circuit board is powered on and ISP cable is connected properly or not. If all ok, it maybe the chip is damage.
发表于: 2018-1-27 11:56:07
RT809H,怎样读取KB9012 A3,请群主详细指教,看过RT809F,教程,不明白,两种编程器,插座不一样大,并且没有插座的详细针脚定义,在线等,群主辛苦。
发表于: 2018-1-30 10:00:30
谢谢版主分享经验,辛苦了
GMT+8, 2024-4-19 15:40 , Processed in 0.055561 sec., 10 queries .
